Carb question
Hello fellow hudsonites,
I recently managed to wake up my 54 Super Wasp and made a good little ride with it and everything runs great, minus a rough idle, especially when the transmission is on drive.
While taking a visual inspection prior to check the ignition timing, I found out that
I may not need to set it.
As seen on the picture ( sorry for the picture being sideway), Hudson did put a guide for the distributor setting and it seems to be already set as it should be, wich is 9 degrees according to the shop manual, yet the engine does have a rough idle. Then I did remember something regarding the carbs: both of the carbs are WA1-2013S wich are used for Hudson Jets and Super Jets while the original carbs that I should have on the Super Wasp are WA1-2114S.
My curious question is this; Could the wrong carb number can give a rough idle, even when everything is properly set? If not, where should I give attention to smooth the idle for the time being? I already have the idea to search for a pair of the proper carbs to set during the next winter.
Any thoughs on this curiosity ?
regards, Tom
I did wip the throttle for a short time to have this result and was already giving signs of a smoother idle on drive gear.
(That was off the top of my head, so is not guaranteed to be an authorized Hudson test.)
