step down dash gauges
blondwookieblondwookie Posts: 241Member
This may sound odd but has anyone reset or moved the position of the fuel and temp gauges? I am thinking about moving my around so I can add an oil gauge to my car. I know that i will to redesign the gauge housing as well as the cover plate to allow the use of the additional gauge. I plan to also move the left and right turn signal a bit further out to allow for some extra room for the 3 gauges. Is this even possible to do and has anyone else done this?
  • GlowplugGlowplug Posts: 2,255Expert Adviser
    There was a participant on this board in the past who designed and built replacement gauges for Hudson dash that added functionality in the available space. I failed to capture his contact info.  Maybe others will be able to provide that to you.
  • GeoffGeoff Posts: 4,356Senior Contributor
    Bearing in mind there are three different dashboard layouts in Step-Downs.
  • blondwookieblondwookie Posts: 241Member
    I have a 48 super six club coupe. Can I use a later dash?
    Yes the dashes unbolt and can be substituted
    Do you have pictures of the different kinds of dash gauge units
  • GrimGreaserGrimGreaser Posts: 826Senior Contributor
    I may be able to help... if you're patient and can put up with a guy with way too much on his plate... and poor planning skills... ? Currently working on a new set of revisions, ones that are not nearly as kludged together... Microcontroller driven electronic gauges.
    All of this is behind the steering wheel. Mine is in the center if the dash. How much would I have to change to put the dash pack behind the steering wheel
    What's the year?  I may be able to make my center cluster work... or make adjustments as needed.
    Sorry Grim ? the dash shown is the same 1950 - 1953  install one of those instead of the existing dash... then use the Grim’ Great Gauges!
    Grim I got your stuff captured again!  Ken Cates
    My car is a 48 super six club coupe
    My car will be a full 12 volt system. I already have a working GM HEI in the engine. As well as well as a GM alternator.
    Ah, you have separate, round gauges in the center.   I can probably work something up with those... I can also add additional functionality to the larger speedo and clock... If your interested send me a PM. Also, while I'm here - Glow!:
    Need to check long term durability... this material is not known for temperature stability...
    Sent you a pm
