Hi John when I got my clock gone through the clock guy told me to use a 2 amp fuse no higher because you could burn your clock points in the event your battery went to low and the points were closed and you did not have enough juice for them to open.
If you connect two or more than two fuses in series nothing will change. It functioning as the single one. Every fuse has some limit for current if it exceed it will burn. But if you connect in parallel then the total current carrying capacity will increase.
