Sorry for the previous posting
Somehow the forum got included.
For those interested in improved original generator performance, been working with Gordon at Clover Systems to tune one of their electronic regulator products to the 29 generator mod'd to 2 brush with field externally controlled. I've posted about this before and am now finalizing the implementation. The 2 brush mod has yielded a gain of 5-7 amps. The field coil is about 1-1.5 ohms pulling 5.5 amps in a constant applied voltage test, about 3A @3v under regulator pulse. The electronic regulator is pulse width modulated at 50-150HZ giving better efficiency and smoother battery management with an expected gain of 2-3 amps additional. The test will be under actual load and brush/commutator temperature monitored.
Gordon's company below. Great people!
-----Original Message-----
From: Jack Mcmullen forjack842@aol.com [HudsonSuperSix16-29] <HudsonSuperSix16-29@yahoogroups.com>
To: Sales <Sales@CloverSystems.com>; HudsonSuperSix16-29 <HudsonSuperSix16-29@yahoogroups.com>
Sent: Mon, Nov 20, 2017 9:54 pm
Subject: [HSS] Re: Dynamo Regulator Shipping Notice
Hi Gordon,
Outstanding! Looking forward to testing!
To: Jack Mcmullen <forjack842@aol.com>
Sent: Mon, Nov 20, 2017 1:26 pm
Subject: Dynamo Regulator Shipping Notice
Your dynamo regulator will ship today. USPS tracking number is 9405809699937099414306.
Settings are documented in the back of the instruction manual.
Regulator was tested with 1 ohm field coil resistance.
The regulator symptom you describe sound like sticking relay
contacts. Yes, our regulator uses low frequency PWM just like the
mechanical ones. Frequency varies with output voltage, and dynamo
characteristics like field and armature resistance and inductance.
Frequency is typically 50 - 150 Hz.
Let us know if you have any trouble or need any help. Also, if you
have any photos of the Hudson, we'd love to see it!
Gordon Rudd
Clover Systems
http://www.cloversystems.com
Hi Gordon,
One question, in your knowledge what operating case temp should consider maximum safe; if I monitor the back 1/3 area (brushes & commutator).
I also was a bit confused at the difference of measured ohms versus measured current versus calculated current. For the first current reading I used a straight 5 A meter. That pegged. So I did the Simpson, old but reliable. In any case we'll see how your module performs.
I belong to the 1916-1929 Hudson group (HudsonSuperSix16-29@yahoogroups.com) and have been talking this modification up for a year or two. Now I'm proving my hypothesis. This mod keeps the original generator.
Attached are some pics of my 29, its motor and dash. The seats are period incorrect and are now at upholsters being correctly done.
Thanks for all the help,
Jack
Gordon Rudd
Clover Systems
#ygrps-yiv-232237549 #ygrps-yiv-232237549AOLMsgPart_1.ygrps-yiv-2322375492_88371f44-2cf2-49a0-832f-ce4f23933966 td{color:black;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp hr {border:1px solid #d8d8d8;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp #ygrps-yiv-232237549aolmail_hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp #ygrps-yiv-232237549aolmail_ads {margin-bottom:10px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp .ygrps-yiv-232237549aolmail_ad {padding:0 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp .ygrps-yiv-232237549aolmail_ad p {margin:0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mkp .ygrps-yiv-232237549aolmail_ad a {color:#0000ff;text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ygrp-lc {font-family:Arial;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ygrp-lc #ygrps-yiv-232237549aolmail_hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ygrp-lc .ygrps-yiv-232237549aolmail_ad {margin-bottom:10px;padding:0 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_actions {font-family:Verdana;font-size:11px;padding:10px 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity span {font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity span:first-child {text-transform:uppercase;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity span a {color:#5085b6;text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity span span {color:#ff7900;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_activity span .ygrps-yiv-232237549aolmail_underline {text-decoration:underline;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_attach div a {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_attach img {border:none;padding-right:5px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_attach label {display:block;margin-bottom:5px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_attach label a {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody blockquote {margin:0 0 0 4px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_bold {font-family:Arial;font-size:13px;font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_bold a {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody dd.ygrps-yiv-232237549aolmail_last p a {font-family:Verdana;font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody dd.ygrps-yiv-232237549aolmail_last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody dd.ygrps-yiv-232237549aolmail_last p span.ygrps-yiv-232237549aolmail_yshortcuts {margin-right:0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_attach-table div div a {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_attach-table {width:400px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_file-title a, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_file-title a:active, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_file-title a:hover, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_file-title a:visited {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_photo-title a, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_photo-title a:active, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_photo-title a:hover, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div.ygrps-yiv-232237549aolmail_photo-title a:visited {text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody div#ygrps-yiv-232237549aolmail_ygrp-mlmsg #ygrps-yiv-232237549aolmail_ygrp-msg p a span.ygrps-yiv-232237549aolmail_yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_green {color:#628c2a;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_MsoNormal {margin:0 0 0 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody o {font-size:0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_photos div {float:left;width:72px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_reco-category {font-size:77%;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_reco-desc {font-size:77%;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody .ygrps-yiv-232237549aolmail_replbq {margin:4px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg table {font-size:inherit;font:100%;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg select, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody input, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody textarea {font:99% Arial, Helvetica, clean, sans-serif;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg pre, #ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody code {font:115% monospace;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg * {line-height:1.22em;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-mlmsg #ygrps-yiv-232237549aolmail_logo {padding-bottom:10px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-msg p a {font-family:Verdana;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-msg p#ygrps-yiv-232237549aolmail_attach-count span {color:#1E66AE;font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-reco #ygrps-yiv-232237549aolmail_reco-head {color:#ff7900;font-weight:700;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-reco {margin-bottom:20px;padding:0px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ov li a {font-size:130%;text-decoration:none;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ov li {font-size:77%;list-style-type:square;padding:6px 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-sponsor #ygrps-yiv-232237549aolmail_ov ul {margin:0;padding:0 0 0 8px;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-text {font-family:Georgia;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-text p {margin:0 0 1em 0;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-text tt {font-size:120%;}#ygrps-yiv-232237549 .ygrps-yiv-232237549aolReplacedBody #ygrps-yiv-232237549aolmail_ygrp-vital ul li:last-child {border-right:none !important;}
