52 - 54 rear axle
This may have been covered before, but I can't find anything.
Is there a posi-traction unit for these rear axles? Part #?
Are flange type axles & brake drums that will work in this axle? Part #s or application?
There are posi units out there for 19 spline dana 44 rears.No flange axles that I am aware of for the Hudson dana.May be better off converting a late model rear end.0
19 spline danas were used in a number of applications and you can buy them still today:
https://www.ronsmachiningservice.net/dana-44-2/
Fred_Pitz said:This may have been covered before, but I can't find anything.Is there a posi-traction unit for these rear axles? Part #?Are flange type axles & brake drums that will work in this axle? Part #s or application?0
xxxcrazyuncleharry@gmail.com (without the xxx) has done some research on posi gears for Hudsons
I know the Stude guys have a flange axle conversion for their rear ends. My son talked to a Stude guy about doing one for a Hudson. This was some years ago. I do not remember the guys name. I picked up a Stude trans and rear end this week. I have not had a chance to check out the rear end. I don't know what I really have. The trans was a T 96 with OD. The rear has a tag that has W 41/9 on it.0
The stude dana 44 axle size is different then the Hudson version, bearing size is smaller. I posted pictures a few years ago. Ted Harbit, renowned owner and racer of the 51 Studebaker "Chicken Hawk" originaly came up with the stude flanged axle conversion. Fairborn Studebaker now has them made up. Conversion for Hudson dana was discussed with him as well. They didnt feel that the market was good enough to warrent production.
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
