New Castle battery 6/12 volt
Does anyone out there have any info on now defunct New Castle battery co 6/12 volt battery that that switched on to 12 v. to starter and then back to 6v. for normal operation  once engine started?
  • I have an Orpin model B switch and a double volt battery on a Franklin. Anyway, here is link to a discussion on all that.
    https://openforum.hetclub.org/discussion/10192/12-volt-start-6-volt-run
    You will have to find a switch on eBay, but these are rare. I have an extra I can sell since spares are really not needed.
  • RichardD
    edited July 2018
    Here is switch schematic> note the special battery shown with the center posts so as to get 6 volts (in series). Parallel would give you 12 volts. anyway, this is it.
  • Richard , weren't those Orpin switches made in Goldsboro?
  • RichardD
    edited August 2018
    The batteries with the switches on them were sold there. Have seen the old popular ads but don't remember the name right now. The Orpins I have came individually in their own boxes. Went on a ebay search for these years ago.
  • Richard, how much do you want for your spare switch?
  • RichardD
    edited August 2018
    Edit: gone.
  • One I had about ten years ago... used it to combine a couple of batteries for a carry around starting battery box.   Now you can buy the same thing already manufactured in a rechargeable unit. Who would a thunk?
  • Just a thought would a pergo switch from a boat work you can switch it to2 battery to start or 2 battery  to charge just my 2 cents
  • RichardD
    edited August 2018
    Edit: spares are gone.
  • Trying to get my 37 Terraplane windshield wipers working. Does any one out there have a good working motor ? linkage is all fine. Tried squirting WD 40 into inlet and working arms back and forth. No luck . There is a number on body 8k40 or bk40?
  • Might want to have Ficken Wiper Service on Long Island rebuild it for you. Worked for me.
  • Karl, may I suggest that you start a new discussion, rather than tagging your inquiry onto the bottom of the one about batteries? I think you'll get more responses that way. You certainly deserve "your own" discussion.
  • Thank you , Couldn't figure out how to get new post. Sometimes it works fine
