For those interested, a quick photo drop of current projects
GrimGreaserGrimGreaser Posts: 802Senior Contributor
Here's a couple quick pictures of my current projects:
  • jjbubaboyjjbubaboy Posts: 821Senior Contributor
    Looking awesome! Great job!
    Jeff
  • ValVal Posts: 798Member
    Very Nice!
  • hudsonsplasher1hudsonsplasher1 Posts: 733Senior Contributor
    Very nice work.
  • triman62triman62 Posts: 214Member
    Some very interesting projects, nice work!
  • GrimGreaserGrimGreaser Posts: 802Senior Contributor
    "Meat-space" 80% radiator install. There will be a custom chevy adapter for a swivel water neck to accomodate the passenger side inlet.
    Spaced 1-1/4" to make room for fittings.
  • bluenashbluenash Posts: 34Member
    Love the tank. Quite a job.
  • 33kc198933kc1989 Posts: 369Senior Contributor
    Nice work.
    Pretty much ready to drive around... Get a coat of paint on the fenders, and give the state of CO their vig and I'll be good to go...
  • KdancyKdancy Posts: 2,385Senior Contributor
    Grim, did you get the tach you were working on completed ? Also, tell us about the fan pulley, are you using the stock crank dampener pulley with it ? What is the advantage on that style radiator ?
    edited May 2018
    Tach and gauges are nearly complete, have some circuit board and enclosure details to iterate and finalize.  I have a later model GM dampener with a short-water pump style crank pulley, and that water pump pulley is for a Ford Racing Short Water pump, but I had to swap out the hub for the proper bolt pattern. Radiator is a Speedway universal dual path cross flow unit, 26" wide.  https://www.speedwaymotors.com/Speedway-Double-Pass-Aluminum-Radiator-Chevy,23864.html
    Some quick numbers from my cooling system:
    180° thermostat, 7 psi rad. Cap
    Rad. Inlet ~170°
    Rad. Outlet ~130°
    Measured w/ K-type thermocouple on radiator surface
    @ idle (after quick trip to gas station and around neighbourhood) with just stock fan as seen in picture.
    Little farther along... Electric cooling fan and shroud:
  • bent metalbent metal Posts: 1,567Senior Contributor
    Good stuff. :)
  • TwinSuperchargedTwinSupercharged Posts: 25Expert Adviser
    Interesting that I see most Hudson's with the coil mounted pointing down. Most mfg MSD, Pertronix recommend pointing it up to insure the oil is covering the internals. Any issues??
    No problems for me so far.
  • JasonNCJasonNC Posts: 886Expert Adviser
    Grim,
    Why the different air filter on the carb? Is that a standard carb? What kind of filter is that? Looks like it makes it easier to work on the engine without the standard air filter.
  • GlowplugGlowplug Posts: 1,835Expert Adviser
    What material did you use to construct your radiator shroud?
    The air filter is one of those universal K&N types that I found to fit a Rochester 4GC I have, but it fits great on the filter adapter on the Carter WGD. Much better than the oil bath filter I had.
    The shroud is made out of some sheet steel I had. I would of rather used aluminum, but it turned out pretty good and looks pretty slick painted red.
    What is the number on the K & N air filter?  Better yet, what are the dimensions?
    Not a K&N... Airaid or Spectre...  I will have to look it up.
    This one one I beleive...
    https://www.spectreperformance.com/mobile/product.aspx?prod=8168
    There are other colors.  Mine is clamped on the base of one of those 2bbl universal 4" filters.
    Some updates: current engine layout, gauges and lights, and seats/safety belts...
  • PaulButlerPaulButler Posts: 841Administrator
    Wow, those gauges really stand out! It's looking really good , great work
    Another shot of the engine:
    Speedway Motors aluminum dual-pass radiator and a custom made electric fan shroud.
    edited August 10
    Like the fan shroud. I need to build one for my custom 53 studebaker coupe.
    Very nice upholstery.
    Are all the guages now ready for sale?
    Also interesting seat belt arrangement for 3 pt belts, i need to look into that.
