Info Needed 53 Hornet Thermostat & Spark Plug Leads
PeterD
Hi, I am needing a Thermostat and Spark Plug leads for my 53 Hornet 262
Does anyone have a part number for the Thermostat, and is there a Universal Lead kit available.
Thanks - Peter
Peter, I have those origional type thermostats. email me at HEThornetllw@yahoo.com Drop the HET when writing.0
For plug leads: you can still get wire sets thru NAPA. I don't have the Belkamp part number right off, but Ken Cates' website should have it. If you want the fabric covered original type, my neighbor John Brillman sells reproduction that are beautiful and fairly priced. Www.brillman.com0
The White Triangle News has numerous people listed to satisfy all of your Hudson needs. Look under Member Products and Services, and Parts For Sale. Membership has it's benefits!
John0 -
There are a couple of things to think about with the plug wires. They need to be 7mm to fit through most plug wire holders. If your staying with points and condenser you can use original type wire core. If you are going with electronic ignition (Petronius) they recommend suppression core not solid core. Morroso makes 7mm suppression plug wire kits for flathead Fords. I buy them from Speedway Motors, but most any speed shop deals with Morroso .0
Spark Wire Set40 - 47, 6,NAPA7438,48-56, 6,7460,8cyl74490
Thank you all for your comments. I have purchased some leads now, and a thermostat.
Pete
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
