Tune Up Part Numbers
iceblade10
I'm wondering if anyone has the part numbers handy for the cap, rotor, points, and condenser for a 1954 Hornet? Thanks.
Thank you, Oldfarmer. I was hoping for magical NAPA numbers that I could use to stock up on these parts, but it doesn't look like it's going to be that easy. WRP sells a tune up kit for $60 plus shipping, but that seems pricey to me. I guess this is why some people choose to go electronic...0
One thing to factor into the cost of converting to electronic ignition is the cost of a tow home. LOL
onerare39 said:One thing to factor into the cost of converting to electronic ignition is the cost of a tow home. LOL0
Stephen,here are the NAPA numbers,cap-AL106,points-CS719A,cond.-AL869,rotor-AL112,NGK plugs are B7HS ,got this number from member the original Champion number is H11 for '54 but not made anymore,CH10 replacement but they are one step colder than called for,if you can find an older store that still has catalogs you might find a direct cross to another company. But if you can find a place that sells Standard Ignition they are better parts and ask for Blue Streak which is the better line with brass contact parts,NAPA went to Echlin that are all made in Mexico.I put a set of NAPA points in my '54 just yesterday,and wouldn't even fire,cleaned the old points that look like Standard and she fired right up,first time I heard her run since I bought her two years ago!!! Runs like a top.Rock Auto sells Standard and they should be able to cross NAPA's numbers,and Standard also has an on-line catalog.0
What ignition breaks down and causes a tow?
When was the last time you did a tune up on your newer car?
There are factory style electronic ignitions that can be retrofit on the Hudson.
But they are 12v.
Ice, Send an email to xxxdbasauto@aol.com (remove xxx) with your needs. Tell him eddie hudson sent you0
BTW, Rock Auto lists all these parts for your 540
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
