Jethroe, 1946Hudson Pickup truck
Fred, I can help on bushings, frame and shock clamps. I also can help with a 262 block.0
Fred,
Dont despair.. The frames found here on the East Coast usually are rusted out up over the rear end.and usually can be 'fish plated' by a frame Shop to be stronger than original. There are a couple Shops here in Erie that specialize in Frame Repair, and not too costly. Car Frames are identical but shouldnt be necessary for just a few rot spots that I can picture on your truck..
Randy Maas can probably help supply you faster with a complete rebuilt Motor, the Bushings, and the Shock Plates.
(Local Machine Shops usually take longer to work a Hudson Motor thru because their unfamilar with them).. Ive usually waited over a Yr....
The right way to do a rebuild is removal, but Is your motor knocking or blown up? If not, you might get by with having an 'In-Chassis' rebuild on your current motor by grinding the valves, new Timing Chain, honing the block, and install new rings & bearings locally..
Garages will require you to buy the Parts since they wont know where to obtain yhem but any good Shop can do the labor...The Parts are readily available and Hudson Motors are simple when compared to todays motors.
Freds truck has had the frame spliced in at the rear if my memory is correct. I think they used channel iron
at the splice. I think it was a car frame with lighter springs that was spliced in. Maybe a frame from a low mileage car would work , than the front end wouldn't need all the parts?
Thank's everybody. I'm digesting all the info at the moment. I changed the truck springs to car springs in Jethroe because with Ohio roads my head was more in the headliner than my ass was on the seat. I won't do that again.0
Folks, i don't know whats hppening here but I can't respond to any of the above messages. Please help!0
Fred , mouse over the " Handle" ( forum name) of who you want to contact and left click on it.
When their page comes up , there will be a box at the left top that has a blue shadow.
Says send message. Left click and use the form that comes up.
Good luck
Roy
Fred, are you trying to respond to each person by message or reply individually to each post?
Got your email, on the road making my way to Hershey. I will reply when I can.
Aaron0 -
Look to the right, under "Forum - Instructions & Tips". The message you might be seeing is most likely the 'Body is Required' error message. If it is, here is the workaround -http://openforum.hetclub.org/discussion/165430/wysiwyg-issue-body-is-required-#Item_1
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
