OD transmission markings
ValVal Member
edited March 13 in HUDSON Posts: 267
I bought an OD Trans for my car at the suggestion of the good doctor and was wondering how to decode the markings on it. are they set to any certain type of car?
  • Uncle JoshUncle Josh Senior Contributor
    Er...what markings?
  • ValVal Member
    Well on the bell housing it has 800013 2  and 4350 cast on the rear face of the bell housing. looking forward on the right side it shows R10D-1A  W.G D V  and towards the front it is cast 301 839 IDEAL 3 10 50
    Dunno, but there are 2 different bell housings for the big six.  The single lever type bolts to the tranny with 6 bolts from the inside of the housing, and the double lever type, bolts to the tranny with 4 bolts from outside.
  • ValVal Member
    Uncle Josh It is a single over drive transmission I have to wonder if it isn't a 1950 model as the " 3 10 50"  seems to be in date format. If so I cant decipher a 1950 what? I asked the person I bought it from but he isn't sure other than that is  48-51 year model. I just would like to know because if I ever have to do anything to it I know what it is I have.
  • Ric West INRic West IN Senior Contributor
    As you guessed, 3 10 50  is the casting date.   Ideal is the foundry,  externally the 48-51 are all the same. and will fit all four years.  There may be some internal ratio differences
    if used with drive master/Supermatic.  Is much different than your 39.  Not sure it could be adapted without much modification .
    "Ric"
  • ValVal Member
    Ric, Thank you so much for the date confirmation as well as the foundry info.  I bought the one that DR Doug told me to get and he will make the modification so that it fits. He will have to use my existing bell housing and shorten my drive shaft. I guess there is no way to know what cars they were in?
    That will work!  So much nicer on the highway with the overdrive!
  • ValVal Member
    That's what he said that it would give me the ability to drive the freeway without getting run over. Although I wont do much freeway driving with the car. I will drive it home from his place and don't want to do it at 45 mph the whole way
  • allanallan Member
    Val, I have one of those transmission in my '38.  There are some mods, but nothing too horrible - Doug can handle them.  I drive my '38 65 and 70 mph all the time with a 4:11 rear ratio.  Love it, and have a ball doing it!
  • ValVal Member
    edited March 15 Posts: 267
    Thanks for the info allan I look forward to driving her home
