Oil Pump Gear Big Six R & R
The new oil pump gear I bought a while ago has only one hole for a taper(?) pin. In shop manual is shows (barely I think) two holes for old pin to be driven out. On removing gear off old ;ump I see the pin on both sides of the shaft. On a 308. How have you dealt with this or do other gears have both opposing holes (usually one smaller than the other for taper pin). ? Gert
