Wanted 4.1 gear and pinion set for Dana rear axle
Looking for a 4.1 gear and pinion set for a 52-54 Hudson Dana rear axle.
Thanks.
  • 4.10 was standard on the Hudson build rear ends. 4.09 was standard on the Dana rear ends from 52 on. Pretty sure I have both. Could you tell me which one is the one you want?
  • 4.09 for the Dana, car is a 53 Super Wasp.
    Thanks
  • Well looks like a have several 4.10's Hudson built and  a couple of 4.55 for a Dana but they won't help. I do have a 3.07 Dana  for a 53 hydramatic if that helps.
  • Appreciate you checking, I'm not wanting to go as tall as 3.07 gears.
