Dana-Spicer gear swap question
I have a 1954 Dana-Spicer with 4:55 gears removed from a Hornet. I want to swap to a 3:07 set of gears since I have
switched to a 2004r trans. I'm told in addition to changing the ring and pinion that the carrier will also need to be changed to mate with the 3:07 gears. So, now what about the axles, do they need to be changed as well or will 4:55 axles work with 3:07 gears. Any help much appreciated.
All 52 -54 rear axles on Dana 44 Hudson rear ends will interchange. Ratio does not matter.0
My research shows that 1954 Hudson dana rear end had 1 1/2" 19 spline axles. Is this correct?0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
