Clutches, Pressure Plates & Flywheels
I have a 9” in my 37 Hudson which is bad. I am looking to change to a 10” setup. Will all 10” items work or are there only specific years that will interchange? What are the differences & please show pictures if you can. I have a pressure plate & clutch disk but not sure if they can be used or what I’m looking for in a 10” flywheel. Thanks
I have a 1935 clutch in my Hornet, so yes, any 10 inch unit will work.0
Be Careful as there are several different flywheels make sure everything lines up with the pressure plate.0
I have a late model 10 inch clutch disc in my 1934 8 that works just fine. The Railton Owners Club advice is that you can use a 10 inch disc in any 1934 onwards car that took a 10 inch clutch.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
