1935 Generator test.
TerriblePain
A wire was disconnected from the generator on my straight 8 Hudson by the previous owner who had passed away. That made me assume it must have a problem.
With the car running, I cannot get any voltage when reading between the terminals or between the terminals and ground.
I see guys on YouTube will connect the two terminals with a jumper and touch that to the negative battery post (for a positive ground car) and see if it spins like a motor.
Is this method advised...or has anybody tried it?
What is a good source for these generators? I assume they are fairly unique.
Thanks.
Thanks.
Which wire was disconnected? A or F? If you ground the F wire and connect the A wire to the battery, with the fan belt off, the generator should spin with a current of 4 amps. If it does not the generator is faulty. It is not a big job to fit any generator from a post war Hudson, Chrysler, Packard, Studebaker etc. (all Auto-Lite) and a matching voltage regulator.0
The A wire was removed.
I will try that test.
If it seems to work, can I hurt anything by reconnecting it if the voltage regulator is bad? Can the regulator be tested?
The former owner had 19 cars he tinkered with. I assume he disconnected it for some reason.0 -
I hope it wasn't a bad idea, but my friend hooked the battery charger positive lead to F and the black lead to A. The generator didn't spin.0
I would do it with an actual battery. I don't think a battery charger generates enough amps to do the trick.0
You were correct. The battery charger didn't spin it but the battery did.
I hooked it up and started the engine. I get no change in voltage (between engine running and not running) at the battery and the ammeter light still glows.
My friend said to short between the A and F terminals to 'polarize' it while it is running. I tried a few times. I didn't get a spark between the two terminals and voltage at the battery stayed the same.
I cleaned all of the connections on the voltage regulator....still no change.
Any suggestions appreciated.0 -
You need to check the current when the generator is spinning with the battery negative connected to A and the positive connected to F, and also the the generator casing. It should be 4 amps. If higher or lower than this your generator is faulty. Have you checked the brushes? Could be an open circuit field coil. You really need to take it to a qualified auto electrician. You can try manually closing the cut-out points with the engine running. If they do not stay closed the generator is faulty.0
Another thought, have you tried advancing the third brush? Move in the direction of rotation to increase charge0
Today I removed the little cover from the back of the generator. I snapped all of the brushes a little to help them make good contact. I carefully ran a pick along all of the grooves between the copper segments to remove the black debris. I gently rubbed a blackened area on the copper segments clean with a brillo pad.
I hooked it back up, started the car, and read the voltage at the battery. It was still at 6.49.....my normal battery voltage.
I set my screwdriver between the A and F lugs quickly, which generated a spark, and measured the voltage at the battery. It was 6.6 and the Ammeter light on the dash went out.
I am not an expert by any means, but this got mine working.
Thanks again for the help to commenters above.0 -
The light may have gone out, but this by no means indicates the generator is working correctly. You need to disconnect the A wire and fit an ammeter in there to see what amperage the generator is producing. Is yours a simple cut-out, or a two stage regulator?0
I don't know what kind of regulator I have. It is about an inch wide and two inches long. I will try to measure amperage.
I was getting about 6.8 volts at the generator and 6.6 at the battery with it running.0 -
Sounds like you have a cut-out with no regulator. The current is increased by moving the third brush in the direction of rotation. There should be a cap on the F terminal grounding it if that is so. Is this a Terraplane Special?0
I think my car is a plain Hudson. It did have two tail lights and vent windows back in its day. Someone told me that it might be a Deluxe because of those items.
Which brush is the third brush?
The wire leaving the F terminal of my generator does get grounded by one of the bolts holding what I call the regulator to the firewall. I don't have a cap on the F terminal that I know of.
Thanks0 -
The third brush is the one you can see when the cover strap is removed. it is held in position by a flat spring, and can be moved.0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 68 Hudson 8
- 592 Vehicles
