Ira Vail style racer project looking for transmission advice.
Hello, I am a new member of the Hudson Club and new to the forum.  I have acquired a 1922 Hudson chassis and front sheet metal with cowl. I have made a deal to buy a 47 Hudson straight 8 eng/ 3 spd. trans.  I believe the 47 transmission will be a column shift. Can I replace the 47 transmission with a earlier 3 sp. floor shift?  If so ,what years will work?  I will also be looking to buy a 3 spd floorshift trans and my 47 trans will be up for sale.  thanks in advance for any help and direction you can share with me.  Don
  • If possible, go for a '38 or '39 transmission with the fine spline shafts, and  if possible find a '40 overdrive. Otherwise it would not be impossible to  conjure up a floor shift  to adapt to the '47 transmission.  This way you could use the more easily available R10 overdrive.   However being somewhat of a purist, I could suggest that you use an original Super Six set-up.
