Do I Need to Replace my Clutch Fingers ?
Old Fogey UK
Should the tips of my clutch fingers look like this ?
Could they also be part of my gear shifting problem ?
They should not look like that, and should be replaced.0
54coupe said:They should not look like that, and should be replaced.
How should they look ?
Are replacements available in the USA ?0 -
Doug Wildrick would be your best bet. The tips of them should have a radius. Probably about 4-5 mm radius. I don't have one nearby to measure.0
54coupe said:Doug Wildrick would be your best bet. The tips of them should have a radius. Probably about 4-5 mm radius. I don't have one nearby to measure.
I’ll give him a try.
If you can't find new one ones, you can rebuild them with Hardcraft arc welding. Just a blob on the ends and re-grind them. Clamp the three together and grind all to the same rounded profile.0
Wildricks don't sell clutch fingers only complete assemblies that would be mega-expensive to ship to the UK.
Any other suggestions where I could get fingers, please ?0 -
Geoff’s suggestion for a repair method is an excellent idea.
regards, Tom0 -
tigermoth said:Geoff’s suggestion for a repair method is an excellent idea.
regards, Tom
All I need is a traced outline of a perfect clutch finger to guide the amount of welding and grinding.
Please could someone oblige ?0 -
I will try looking at mine tonight and let you know.0
Using a machinist radius gage set the curvature end is 1/8 radius with the relief behind the nub as shown in your photos. There is a definite curve to the ends.0
A profile grinder (not by hand but like tool and cutter grinder) with an 1/8 inch profile ground into the wheel at a machine shop should be able to do it. On the other hand is there not a good set of fingers someone can send to UK ?0
Try Ron Fellows as well. He rebuilds clutches too.0
The Hudson Master Parts catalog 1948-54 shows different part numbers for the 9 and 10 inch clutch fingers - the Shop Manual makes note of setting finger height .005 or .010 - also the number of internal springs is different for 9 and 10 inch . As I recall you had a 10 inch plate and a 9 inch disc was mistakenly added for generous grief. You are going all 10 inch once parts are found. I found a good 9 inch pressure plate thinking the fingers all the same and had it on the hydraulic press but then checked the manual and no go. Gert0
Thank you all very much for the helpful advice, I'm really grateful.0
Don't know if this will help but here are a couple pix. The black one is good. the silver one is worn probably like yours. The grid blocks are 1/4" square.0
Looks like someone with a wire EDM or water jet could knock a lot of these out in no time!0
35Terra said:Don't know if this will help but here are a couple pix. The black one is good. the silver one is worn probably like yours. The grid blocks are 1/4" square.
Thank you x 1,000,000 !
We should be able to work with this.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
