1935 Hudson Body service Manual
Trevor J
Trevor J Expert Adviser
Does anyone know if there is such a thing as a body service manual for a 1935 Hudson.
I am putting my 35 Coupe together which was a kitset when I got it.
I want some pics of the door parts.  Ive got the winders and locks sorted but want pics of the door window channels.  The front one is sorted but trying to figure out the rear Chanel that the glass runs in and how it fits in the top of the door.  Any help would be appreciated Thanks
  • Old Fogey UK
    Old Fogey UK Expert Adviser
    I used flexible metal channeling that was covered in rubber with black furry cloth on the outside.
     I think the original was glued in place but I used small stainless countersunk self tapping screws in the base of the U-shaped window channeling to attach it to the window frame.
  • KEL 39
    KEL 39 Member
    Trevor
    Here are side views from Master Body parts Book 1930 -1939
    Hope this helps.
    Ivan L.
  • Trevor J
    Hi There. Thanks for the help.  I thought I was missing something but it appears that the rear window channel attaches to the body either screwed or glued to the metal part of the door.  My door is described in plate 4 above but does not give detail relating to the window channels
