Con Rod Bolts for 1934 254 cu in - Modern Equivalent ?
Old Fogey UK
I'm about to reinstall my pistons and rods after a honing job but the threads on the con rod bolts don't look too good.
Has anyone who has rebuilt an engine like mine found NOS original bolts anywhere or used modern equivalent con rod
bolts ?
I'm drawing a blank with trying to find an English supplier of bolts of the right dimensions and specification.
Thanks in advance for any assistance.
(I've also put this request on the Members' Forum)
David.
I think we've got the problem solved.
We've decided to use 3/8" x 2 1/2" High Tensile UNF hex bolts.
They'll have to be shortened slightly and a bit ground off the side of the hex heads.
We'll be using Philidas all-metal lock nuts.0 -
I just removed my pan for cleaning. No more draining since 1954 and stopping. It's super clean and in good condition. An original rod with its small pin
TapeThe original regulation remained on the rods or they were regulated??z votre commentaire0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
