Replace bulb fender lamp Hudson eight 1934???
For the backlight. The wiring is attached with small original fasteners along the chassis
Jack356 I am sorry I was talking about your front small fender light that you just replaced the bulb in I am adding these lights to my car and I wanted to know how the wire attached to the bottom of the fender and were it went into the engine bay.0
The wire passes over the wing support. Return with the headlight cables into the engine bay through the same hole
Tapez votre commentaire0
Thank you so much for the picture Tom.0
I wonder why Jacky's 1934 car hasn't got telescopic shock absorbers ?
I thought they were standard on all Hudsons and Terraplanes from 1934 onwards.0 -
You can see the mounting stud for the original telescopic one. Obviously replaced at some stage. A retrograde step.0
original
Original factory in Belgium.Anvers
SEKURIT JEMEPPES SUR SAMBRE MADE IN BELGIUM
Cleaning
Belgium
I love the look of your car keep the pictures comming you truly have been a great help to me thanks.0
I knew about Hudsons being assembled in Canada, Britain and Australia but I didn't know that Hudsons were assembled in Belgium - you learn something new every day !
The British built Hudsons had to use a fixed percentage of British made parts in them to avoid high import taxes - this was the law in the 1930s.
I wonder if Belgium had a similar law and that's the reason why "non-standard" Belgian lever arm shock absorbers were used instead of telescopics ?
Similarly in Belgium.Anvers CAM car assembly centre
The C.A.M., a subsidiary of the importer Packard assembles Packard but also Hudson;t0
Type your comment
Type your comment0
pub
1974 2019.More climbs on the road since at least 1954.FIRST OWNER0 -
Bulb led
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
