1936 Terraplane Rubber parts needed
RocketRocket Posts: 399Senior Contributor
Dose anyone with a 1936 Terraplane have an old rubber windshiled and the two rear windows above the trunk rubber gaskets that hold the glass in I need them for a pattern so I can get new ones made I believe these are one piece molded rubber gaskets.
  • Jon BJon B Posts: 7,190Administrator
    Wildrick Rubber offers windshield seals for 1936-39.  See https://www.wrphet.com/hudson-window-seals-and-channel .  If it's not one-piece, you could use super glue to "weld" the two loose ends together.
    If you have found a way to have one-piece molded seals made up, there may be other Hudson owners interested in these.  When I installed my extruded seal ages ago, I found it was difficult to bend them in the tight radii found at the corners of the window opening.
  • RocketRocket Posts: 399Senior Contributor
    Hi Jon B that is why I am looking for one that came out of a car for a pattern I am going to pay for the molds to have one piece seals made up not just for me but for any one who needs them for there 36 Hudsons or Terraplanes.
