1938 Hudson country club
2manyprojects2manyprojects Posts: 568Expert Adviser
looking for a gas tank sending unit. thanks
  • barrysweet52barrysweet52 Posts: 554Expert Adviser
    Plenty of after market units with mostly 50mm flanges which will fall thru the tank hole. We need one with a 82mm diam flange. Someone on this site said they used a late 50s Ford one with success. A few club members have got them from Dakota Digital. I will be installing a return line from a 3 way fitting fuel filter at carby to and thru my after market flange
  • BigSkyBigSky Posts: 750Senior Contributor
    I bought this one & used on my 37 Hudson.  It will need an adapter plate as bolt pattern is different.  I bought one & flipped the rheostat 180 degrees so that it was then 90-0 ohms unit.
