Hudson Part Question
Hello,
I found this part on the floorboard in front of the Weathermaster after going for a drive the other day. I got caught in some rain, and had the wipers on. The passenger side wiper stopped working, while the driver's side wiper continued to work. Can someone tell me what the part is? The car is a 1942 Commodore Six.
Thank you, and take care,
Steve Bryson
Steve Bryson
I can tell you. It is a retaining clip for the wiper motor. The left and right wiper towers (or "transmissions" which hold the wiper arms, are connected to the motor by steel arms (unlike the StepDowns, which used cables). Each of the arms had a hole in it, and the hole fitted over steel studs which were welded to a short reciprocating bar on the back of the motor. One stud held the steel arm (or linkage) for the right wiper. The other stud held the arm for the left one.
Something had to hold each linkage to its studs, or it would come off the stud. If that happened, the particular wiper would stop working.
Each of the teardrop-shaped gizmos slipped over the stud after the linkage had been slid onto the stud. There was a tiny groove in each of the two studs. The retaining clip would click into the groove on its particular stud. The spring pulled both teardrops together and the tension held them in place so they didn't come out of the groove.
SO: lie on the floor of the car and shine a light up under the dashboard. Find both linkage arms and fit the hole in each one, over the two studs on the pivoting bar on the back of the motor. Then slide one of the teardrops over one stud, and the other over the other stud and push them over the stud until they click into place. Your wipers are restored!
You can learn to grope up under the dash while sitting in the front seat, and put one of these clips on "blind". Much easier than lying on the floor.
I don't know why this clip fell off in the first place, unless the spring has relaxed. Actually, it looks to be in good tension.0 -
Thanks Mr. Battle!
I suspected it had something to do with the wipers, as the one side stopped working shortly before I found the part.
The wiper motor was recently rebuilt, so I am guessing the clip/spring is a new part.
Your instructions are great, and should make it easier to put the clip back on.
Take care,
Steve Bryson0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
