Heater core hoses??
airbrushguy
Having a senior moment....which hose is supplying the water (inlet) and which is the outlet?
Thanks
Thanks
I try to always put the hot water in on the lowest port on the heater core,
The theory of that is to force the air up and out as the water circulates but I have hooked them up both ways and I’ve never noticed any difference in operation
when I was in high school I worked at a garage and he taught me that. and he said that it was less likely to make noise from the water circulating when the car is started0 -
i am putting a non original engine in my stock ‘49, I need to tap into my lower radiator hose for one line and the head has a fitting for the other line. Which should I route to which pipe of the heater core?
Thanks0 -
AirbrushGuy
I would try to hook the highest port from the heater core to the lower radiator hose because the lower radiator hose draws water into the motor so it would create a suction on that side of the heater core and draw the hot water from the cylinder head0 -
interesting, I was thinking the opposite, thinking more about flow than temperature and thinking the “inlet” would have to get the flow from the bottom radiator hose.
Good thought!0 -
The flow path of the water in your situation would be , hot water out the top of the engine to the bottom of the heater core, out of the top of the heater core ,and then to the bottom radiator hose where it is drawn back into the water pump0
Do I have it figured out yet?
Here is a screenshot from last time you asked this question
it seems to explain it fairly well
hope this helps you out
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 68 Hudson 8
- 592 Vehicles
