Seals
kamzack
kamzack Senior Contributor
Need current part numbers rear inner, outer and pinion seals for Hudson rear. Or a vendor that may have them.
   Thanks in advance,
      Kim
  • onerare39
    edited May 2020
    You didn't mention what year but call Wildrick Restoration, they can fix you right up.
    https://www.wrphet.com/driveline---suspension.html
  • kamzack
    My post says "Hudson" rear. so I gave the correction information. However so you know, It's a 50 Commodore, with  Hudson built rear end. I'm installing a 51 chunk, pumpkin, drop out, comes out the front of housing ring and pinion. and isn't a Dana 44. Please know I'm not trying to be flippant in my response. But have it my mind that, while you fellas have forgotten way more than I will ever know, I gave the correct info. I do thank you very much.
        Kim
  • kamzack
    Ken, Tried to send a PM. How much and How quick shipping to 38451.
       Thanks,
        Kim
    hudsonbaker@myexcel.com
  • Geoff
    Geoff Senior Contributor
    Kamzack, please remember that Hudson made cars from 1909 to 1957, so asking for  a "Hudson" rear seal is rather a broad issue!
