Starter Question
Val
Val Member
Can anyone tell me if a stepdown starter will fit/work with a prewar (1939) car ?
  • Geoff
    Geoff Senior Contributor
    Only if you space it out half an inch.   The ring gear is a different spacing from the pinion longitudinally .
  • What about using a hydro starter on a manual step down car?
    The hydro starter is smaller in diameter than the stickshift starter, where it indexes into the rear engine plate.
  • Ok thank you
  • Val
    Val Member
    Thanks Geoff
  • Geoff
    The automatic transmission starter is completely different, and engages from the  front, not the rear.
