Transmission or rear end?
Took the 49 out for a test drive after making a few changes to the engine. The car ran well except for when I either accelerated rapidly or let off the gas quickly, at which point it the car would lurch and make a loud bumping sound. I can't tell if the "bump" sound is coming from the rear end or the transmission. I wonder if the driveshaft is engaging the rear end too hard or if the clutch is slipping. When decelerating quickly, when the hard thump sound occurred, the car would sway slightly. Any ideas?
I would check the trans mount and the carrier bearing mount first
Did you look under the car? The outcome of what you see may point to the problem quickest. GUESS from afar....the center bearing has has come loose from the mounting insulators, one or both?0
Thanks guys, I'll check it out Monday and let you know....
Ok guys I have checked the center bearing and the mounting insulators and they are ok. Ken I really can’t see if the front eye bushings are bad because the cover blocks my view, but my guess is they need to be replaced. I assume by isolators you are referring to what Wildrick Rubber lists as spring mount bushings #103. Correct me if I am wrong . Thanks.0
Check U-bolts holding the diff to the springs, universal joint nuts, axle end nuts.0
I don't know your level of mechanical expertise, so please don't take offense if you've already checked this, but have you rotated the drive shaft to see how much play there is back at the rear axle? I am not sure what the acceptable play is, but I would think that if it's too much, you'd get a "thunk" back there when accelerating or decelerating .0
Jon B said:I don't know your level of mechanical expertise, so please don't take offense if you've already checked this, but have you rotated the drive shaft to see how much play there is back at the rear axle? I am not sure what the acceptable play is, but I would think that if it's too much, you'd get a "thunk" back there when accelerating or decelerating .
Geoff said:Check U-bolts holding the diff to the springs, universal joint nuts, axle end nuts.
Are your back axle U bolts double nutted?0
Good one Ken. I had to Google that word to see what it meant.....
Some times the second nut is not close to the first. In this situation its called, One Hung Low.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
