212 Crankshaft pulley Bolt
longlivelance
I'm looking for a crankshaft bolt for a 212 engine. I read in the forums that it was a 3/4-16 UNF with a 1-1/2" hex head. I was searching online to try and locate one, but did not find anything. I've attached a photo highlighting the bolt 'm looking for.
Does anyone know where I could find one?
Will need a good clean-up on the crank pulley - probably a bottom tap. Didn't Hudson use same bolt for many years ? Get a used one (from Lance?).0
Thanks for the lead. I did find Lance's website and sent a message about the bolt. 100% going to need a clean up on the crank pulley. Just getting going on the truck and was trying to see if the engine was seized when I discovered the missing bolt.0
Don’t try to turn the engine from the crank bolt when you get one. Try to turn it from the flywheel.0
Lance -check your email.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
