Air filter for Carter two barrel carb
I'm not having very much luck finding an air filter for my two barrel carb that has a 2 5/8 OD. Most of the K & N filters are overpriced in my opinion and the Mr. Gasket air filters with this size neck dimension kept getting bad reviews. I can't figure out how to use the Spectre website to put in the dimensions I'm looking for. Any help will be appreciated.
Back in the 80's when I had a Hudson pickup with a 262, I bought a 4" chrome job with a 2 5/8" neck, from Napa. It looked pretty cool on there, but restricted the airflow severely. Since then, when I change to something other than stock, I buy something with a filter at least 5" in diameter. A good counter man at Napa, who knows how to use a book should be able to get you what you need.0
Mr Gasket #1490 from Summit racing is $26.34. Fits 2 5/8 carb. filter is 2 7/16 tall and 6" diameter. There are others too. Your local parts house can probably order it as well.0
I would use the stock oil bath air cleaner. If you don't have one, they're not too hard to find.but I"m assuming you have the stock carb, not a later Carter 2bbl. The air cleaner mounting might be different if it's a later carb.Providing just a little more info about what exactly you're working on, would be helpful.0
squirrel said:I would use the stock oil bath air cleaner. If you don't have one, they're not too hard to find.but I"m assuming you have the stock carb, not a later Carter 2bbl. The air cleaner mounting might be different if it's a later carb.Providing just a little more info about what exactly you're working on, would be helpful. Terraplane Coupe said: I am using a 1950 254 eight with a stock carter and stock air cleaner.
54coupe said:Mr Gasket #1490 from Summit racing is $26.34. Fits 2 5/8 carb. filter is 2 7/16 tall and 6" diameter. There are others too. Your local parts house can probably order it as well.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
