Voltage regulator
hudsonsplasher1
hudsonsplasher1 Senior Contributor
For all the electrical experts. Installed a new voltage regulator on my 49 Commodore 8, seems to be working except the amp light stays on. Any suggestions to correct the problem?
Thanks in advance,
Gene.
  • If the light stays on only during idle it is fine - this is not unusual for electrical systems with a generator. Below 600 RPM idle, my AMP light stays on.
    There is a procedure to polarize the generator in the service manual. If the generator hasn't been used to charge in a while or been replaced it might not be charging due a need for this procedure which means the warning light is correct.
  • Geoff
    Geoff Senior Contributor
    When you say "seems to be working"  I would have assumed that if the amp light is staying on that it is not working.   What output voltage do you have at the "A" terminal?
  • hudsonsplasher1
    Is there such a thing at polarizing the voltage regulator? If so, how is it done. It was brought up in conversation with other old car owners. I'm not familiar with this.
  • hudsonsplasher1
    I'm going to check to see what output I have. I know it's generating, but don't know how much.
  • Geoff
    No, the regulator is polarity neutral, but the generator must be polarised correctly.  do so by momentarily  connecting the B and A terminal of the regulator.
  • hudsonsplasher1
    Thanks guys, I appreciate the info.
