Looking for passenger side cowl light bracket 29 Essex
As the title says I'm looking for the cowl light bracket for the passenger side for a 1929 Essex.
  • Jay_G
    Jay_G Expert Adviser
    You may want to check eBay.  There have been some 28 Essex cowl light and brackets on there for some time.  They may what you need.  I have found there are many parts that interchange on either side of the year I am looking for.
    Jay
  • 54coupe
    54coupe Member
    29 are one year only. Do you need right or left, as referenced from the driver's seat? Passenger side can vary, depending on what country you live in.
  • oldtoys
    oldtoys Member
    Need right side as referenced from the driver's seat.
  • ted
    ted Member
    On kijiji in London  area Ontario Canada  there is a pair for sale. Type in Essex  and go through.  They will show up.  Brackets and lights.  28/29  not sure look right
  • ted
    ted Member
    What is different  about  28    or 9  just wondering
  • Geoff
    Geoff Senior Contributor
    '28 are brass with screws through, '29 are smaller curved die-cast with studs.
  • oldtoys
    oldtoys Member
    Ted,   Checked KIJIJI.  Those are for a different year.  Very different than mine.  Thanks for the suggestion.
  • If you find two let me know. Im looking for exact same. Passenger side cowl light bracket. 1929 Essex
