1939hudson country club 6 #93
trying to locate a new shift cable that runs from steering column to trany,dose any one know who might have one
  • 2manyprojects
    2manyprojects Expert Adviser
    someone here might know which years are the same which will help locat
    ing one.
  • barrysweet52
    barrysweet52 Expert Adviser
    I think 1939 was the only year cable ran the long long long way around the front of the motor and back to the arm on the gearbox. If you have the ends they are easy to get made
  • Geoff
    Geoff Senior Contributor
    Brake service specialists should be able to make you a new one.  Otherwise, if you can  bring yourself to be non-original, save yourself a lot of bother and  fit a floor shift.  Any gearbox lid from '34 to '38 will bolt straight on.
