Hudson J-2795 brake lever tool
Kdancy
Kdancy Senior Contributor
Anyone have one of these they would be willing to send? I would like to get one to duplicate it for my use.
  • bob ward
    bob ward Senior Contributor
    Is this the tool to adjust the brake shoes?
  • Glowplug
    Glowplug Expert Adviser
    This is the tool in question
  • RL Chilton
    If it works for '50 models, why not '51-'53? I thought they were the same.
  • railknight
    railknight Expert Adviser
    edited February 2019
    The 1952 edition for the Kent Moore tools guide for Hudson shows the same illustration, but the part number's listed as "J 2795 A" and still listed as "Brake & Clutch Pedal Rod Remover."
  • Glowplug
    Kent Moore catalog was older version. It works for all stepdowns
  • Kdancy
    Ken Cates sent me one he has. I am going to build the frame using steel bar stock, then build the "pusher using steel thickwall tubing and grade 5 nuts inside. ( the pusher threads on the brake rod shaft and as you turn it off, its shoulder is up against the frame and pushes the rod out and protects the threads) I'll post pictures when finished.
