Timiing issue
The timing keeps “jumping” .I’ve tightened the distributor and after timing it, it ran good. I went to start it today and the timing was of. This makes the second ignition system to do this. I have gone back to points (instead of the Crane electric eye) after it kept jumping timing. I’ve read a few posts on this forum and it looks like jumping timing is not that unusual with Hudson engines. Is there something I need to do to correct this problem?
You also didn't mention if you were running a 6 volt or 12 volt electrical system. I have heard that the 6 volt systems are not as reliable as the 12 volt systems with these modern points replacements.
