Question, about overdrive.
The Overdrive-Lockout is designed for vehicle applications that are extremely over loaded on a daily basis and for durability purposes are best kept out of overdrive. The lockout switch when activated will disallow overdrive even when the shift selector is placed in the overdrive position.0
Thanks Charles4d0
Overdrive operational and maintenance information can be found on this website under the TRANSMISSION section.
https://hudsonrestoration1948-54.com/0 -
I'm not aware of any such switch as a "Lockout" switch. If you mean the switch actuated by the lever on the housing when the Bowden cable is pushed in, if this is by-passed, then the overdrive solenoid will be activated even when the cable is pulled out, and this will eventually burn out the solenoid. The only way to permanently lock out the overdrive would be to disable this switch so it could not provide a circuit to the governor.0
Geoff, here is what I'm talking about. Maybe it is not called a lockout switch, not sure.0
I'm not around my car right now, but I'm pretty sure mine has the "lockout" switch also. Just an electrical continuity switch that breaks when the transmission is in reverse. I can get pictures of mine later.
I actually had mine off to run new wires to it and clean it a few weeks ago...k0 -
Here's my "before" shot. Trannie on the garage floor. Lockout switch is located toward the tail-shaft with wires attached.0 -
Okay, that is the actual control switch, which does in effect lock out the overdrive when reverse is selected. Is the bypass open circuit? If so this will of course disable the overdrive function permanently.0
Keith, that is a great shot of what I'm asking about. Thanks. Richiekeithfullmeryahoocom said:I'm not around my car right now, but I'm pretty sure mine has the "lockout" switch also. Just an electrical continuity switch that breaks when the transmission is in reverse. I can get pictures of mine later.
Geoff, it is probably just the way the factory wired it except for the bypass. All wiring looks original and unmolested with the exception of that switch being bypassed. To answer your question, I don't know if it is an open circuit. Thanks. Richie.Geoff said:Okay, that is the actual control switch, which does in effect lock out the overdrive when reverse is selected. Is the bypass open circuit? If so this will of course disable the overdrive function permanently.
Thanks Glowplug. Richie.Glowplug said:Overdrive operational and maintenance information can be found on this website under the TRANSMISSION section.
As said above, that "reverse lockout" switch is there to ensure the overdrive can't activate when you're in reverse gear. If bypassed, the OD might try to engage if you were driving in reverse and got above the governor cut-in speed. That might produce loud and expensive noises.0
This may help shed some light. From another site. I have a '49 Ford with the same Borg Warner overdrive.
Thanks Keith and Park. Richie0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
