47 Windshield installation
Google putting in a windshield flat glass
It will show you how it easy to do use it just looks hard I put mine in the 1940 but I read the book when I did mine they do it the same way as the service manual says to do good luck Charles0 -
It appears to me the most difficult part of the installation is cutting and gluing the new windshield rubber surround to the vertical center bar rubber piece. If this had been made in one piece it seems as though it would be simplified. As the pieces from wildrick come the instructions are minimal and you only get one chance for each side. But it wouldn't be fun if it was easy. Use a string with windex as lubricant on the rubber and a good friend to install then the application of sealant and clean the mess with wax and grease remover or possibly paint thinner? Wear surgical type gloves and old clothing that you can throw away. I just need to find the courage to start0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 71 Hudson 8
- 592 Vehicles
