'29 Essex Uni-joints
oldie28
oldie28 Member
edited March 2018 in HUDSON
Hi All,
Looking for replacements for my driveline uni-joints for the '29 Essex, Spicer here in Australia don't recognise the embossed numbers, the online tool at Dana isn't showing a solution. The usual google search isn't producing anything useful.
Any thoughts ?
Thanks,
Darren
  • Geoff
    Geoff Senior Contributor
    There are no direct modern  replacement joints for these.  Only option is to go to an engineering shop and get the drive  shaft modified using modern joints.
  • 4Hud
    4Hud Expert Adviser
    Does it mount to the trans. and diff. the same as a 1930 Hudson? I recently had one made.
  • Geoff
    Yes, virtually identical set-up as 1930 H, just shorter length.
  • Thanks Geoff, that seems to be the way I will need to go.
  • 4Hud
    4Hud Expert Adviser
    Here are some pics of my new 1930 Hudson driveshaft.
  • That's the ticket, I was making some from Aluminium bar.
    Thanks !
