Exhaust Adapters for 6 cyl stepdowns
Now available(again) at Pigeon Forge, TN 26-30 Oct Thanks for your patience, Bob
  • Price for one exhaust adapter to bolt to the bottom of a stepdown 6 cylinder exhaust manifold is $200 plus shipping(USPO flat rate). We should have the 3/8" flanges to weld the exhaust pipes to, price later, can be shipped in same box. Sorry for any delay or confusion. Bob Parks
  • 8 loaded ready to lv for PF. Thanks for the orders.
  • SuperDave
    SuperDave Senior Contributor
    Got mine from Bob. Already did trial fit to a Twin H exhaust manifold. Will post pictures later today. Now I need the matching intake.
  • SuperDave
    I had to replace one stud with a bolt due to the lack of room to start a nut on the stud with the adapter in place. just drilled the threads out of the original manifold and dropped a bolt in.  I also made a stainless shield to keep the exhaust out of the intake. I also removed the heat riser flapper and filled the holes with a couple short bolts. Adapter flange is at the welding shop. I decided to let the pro do the welding. I am going to use 1 7/8 exhaust pipe. It's only a 262 so I don't think dropping 1/8 ' is going to make any significant difference. I am going for the "sound" not performance. Maybe snakeing 1 7/8 pipe through the cross members will be a little easier than 2". Any suggestions on muffler choices? It's a '49 so has more room next to the fuel tank than the 51 and newer.
  • We put two new stainless mufflers welded together beside the gas tank, both exhaust pipes exit together under the bumper. We used 2" pipes front to rear. Thanks for the order.
  • Ol racer
    Ol racer Senior Contributor
    edited November 2016
    Ive seen Hudson Step-down's using a muffler with dual inlet & outlets which I thought was neat but dont know the the part number.
  • Thanks for the questions, first order from CANADA. Price change on Felpro gasket material: w/o holes to match the flange $5,  with holes to match $13.  Thanks, Bob
  • bobdriveshudson2
    bobdriveshudson2 Expert Adviser
    Bump, thanks
  • dougson
    dougson Senior Contributor
    Posted this a while back. I used a Walker Dynomax.
    httpforumhetcluborguploadsFileUpload2167c9aab3df7190255f03fc379c0ee2jpg
  • dougson
    Oops. Meant this post
  • dougson
    I'll try again!
  • Ol racer
    Dual inlet & outlet Muffler is Thrush / Dynomax #17637. It has 2 1/4" in/out so a bushing is required. Cost around $40
  • Nice job, Ken
  • bobdriveshudson2
    Bump, thanks
  • bobdriveshudson2
    We have some adapters ready for sale now  and will bring some to the Pigeon Forge meet in October. Thanks
  • Bump thanks
