springs in the throttle linkage '35 t-plane
hello, what springs are used in the throttle linkage of a 6 cyl. t-plane? just in the linkage, not on the carb. i have one cone shaped coil spring where the accelerator pedal link attaches to the cross shaft (to take up play for the split key) and one on the heat exchanger to the butterfly linkage on the carb (to return the valve to idle setting). after 70 years i am not sure what the factory put on the car. regards, tom
