Spark plugs
blondwookieblondwookie Posts: 355Member
Is the champion spark plugs N4C for an engine with points or for a more advanced ignition system
  • GrimGreaserGrimGreaser Posts: 857Senior Contributor
    Points should be fine. It comes up as a small engine, lawn-mower, type plug when you search.
  • blondwookieblondwookie Posts: 355Member
    The one problem I have is. I have an actual GM HEI built for my engine. I need to find the equivalent plug that would work for an HEI in my 308 engine.
    I have been running a GM HEI and all of my general motors vehicles starting with my 1968 Oldsmobile 442. I had the second generation 400 in my engine.
    HEI won't care, you just need to observe what gap it likes. Just a little bit of test and tune.  Start with a 'average' GM HEI spark gap and go from there.
    So the suggested spark plugs will work with my set up
    Shouldnt be a problem.
  • cheyenne7271cheyenne7271 Posts: 558Member
    Try a gap of .045- .050 and see how it runs.
    51 Hornet Club Coupe
    51 Hornet Sedan
    51 Commodore Six Club Coupe
    50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
    49 Super Six Sedan
    Thanks for all of the input about the spark plugs
