In my mechanical procedure manual it states that in 1937 the engine numbers started with 250,000 & in 1936 terra started at 15,700 & 36 Hudson at 79,000. So with an engine number of 308,537 what year might this have been from, 37, 38, 39?
It will be a 1937 for sure, but you should be able to see the date cast into theblock on the left had side. Will have probably a letter and a number. If the number is 7. this will confirm it as a '37. The letter will be the month, from A to L , corresponding to January as A and December at L.
Good chance it's 1937 engine.
Someone who knows will join in.
