Clutch Adjustment After Installation
I’ve completed the installation of my clutch. Initial I set the distance of pedal arm end to firewall per the manual. Unfortunately I was getting some grinding going into gear. A friend recommended I not worry about the manuals Recommendation but instead set the pedal with about 1 inch of free play.
I did this & it seemed to work. A few days later it appeared I was getting some gear grinding up shifting into 3rd or down shifting into 2nd. So I adjusted the fork 1/2 turn up & that made it too difficult to get into gear when shifting. Thus I put it back the way it was & while it goes into gear much easier I still get a little bit of grinding.
Thus I’m wondering if any experts on clutch adjustment may have advice on how to adjust the new clutch? Thanks!
With the change to top, I invariably get a graunch at anything much over 20 mph - at 15 mph it's as smooth as silk.
He did note my clutch adjustment was off as there was barely any free play in the pedal before the clutch started to release. I tried his 51’s clutch & it was 1.5 to 2” of play before you felt the clutch when pushing in the pedal. So I’ll fix that & see what it does, my only worry is when I had it with more pedal play it didn’t want to go into gear or out of gear. (Not 100% on which way caused what with the adjustment but after the clutch replacement in June it was difficult to get it right.)
