wet clutch material and thickness.
Bernie41Bernie41 Posts: 1Member
HI
Looking for the cork material used on a wet clutch on a 1926 Essex Hudson or whatever they use today, also the thickness of them. If possible that the plugs are already made that would be a great, I believe there are 168, I may be wrong.
Thanks Bernie
  • GeoffGeoff Posts: 4,646Senior Contributor
    No. 5 corks,  trimmed to 1/32" MAXIMUM.  Any more and the clutch will not disengage.
  • BigSkyBigSky Posts: 1,039Senior Contributor
    edited May 22
    I’m gonna throw this out there as I’m sure others will chime in too, but I’d highly recommend sending your clutch to Wildrick if you’re in the United States.
