Speedo Cable Routing - 1934 and 1935 Cars
Please may I have some guidance, please ?
Out in my '34 last Sunday, my speedometer needle suddenly dropped to zero.
The speedo has been rebuilt recently and had a new cable at the same time and the set-up has been working OK.
Investigating the problem, I found the cable all chewed up at the transmission end with no damage at the dashboard end.
The output on the gearbox turns freely and I can turn the speedo needle by hand using the spigot on that end of the cable.
This is the third time in my ownership of the car that I've had a cable fail in exactly this way and the only reasons why that I can think of are -
1. I'm using the wrong cable.
2. I'm not routing it correctly and that's causing it to kink and jam up.
I've been using a Ford 1932-48 (passenger car) cable which is the same length as the original equipment and is listed as a substitute in interchange manuals - is it the correct type ? If it isn't what type should I use ?
Please can someone show me the correct route for the cable (I've simply been putting it where it seems logical for it to go) ?
The inner cable is 61-3/4" and the outer is 61".
Can anyone tell me if this is actually correct before I mess up an inner cable repair kit ?
I'd really appreciate a few pics, please.
My car is LHD, having been bought by me from a HET Club member in Michigan.
I'd be particularly interested to see a pic of the clamp you mention, please, as it's missing on my car.
I had assumed that the cable was routed through the little flute in the top edge of the removeable floor panel - there's another one on the right hand side that I thought Hudson put there for the cable on RHD cars.
From what you say, I've been getting that wrong !
I can't use that hole in the firewall because it takes a load of wiring through it and rerouting it all would be a complicated job.
It looks like I'll have to use the groove in the floor panel again to route the cable.
I've been under the car this morning and I can get it up through there to the back of the speedo without kinking it or bending it into a severe curve.
The problem seems to be at the transmission end where I'm left with a lot of cable length and I'll need to put a loop in the cable to accomodate that.
I'm posting a pic of how Jim DiGiorgio did it on his '34 - does this look like your set up ?
David.
In the past, I've always tightened both ends very snugly and left it at that but I will try your test when I install the repaired cable.
