Clutch Install Questions
Hopefully by this weekend I’ll have things ready to start the new clutch installation on my 37. I’ve picked up some 8” bolts this morning to cut heads off to make pilot studs but wasn’t sure I needed that much length, any suggestions on a length? Next, I’ve read somewhere to use “Permatex” on the crank flange before installing the flywheel. Which Permatex? I’m leaning toward a high temp ultra Permatex so I DON’T get leaks. Really hate all the leaks!
Any other recommendations, tips or tricks?
51 Hornet Sedan
51 Commodore Six Club Coupe
50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
49 Super Six Sedan
I also used a Wildrick clutch kit with the alignment tool.
Using long guide bolts, I could NOT for the life of me get the trans inserted and seated into the clutch. (cue the expression of much anger)
Long story short, the end of the input shaft was too big(!) to fit in the new pilot bearing.
Was the end of the input shaft mushroomed? Sure didnt feel like it.
Was there a wrong part somewhere? Who knows
Eventually I removed the pressure plate and pilot bearing. (lost the new fluid and had to order another gasket)
Then I carefully filed the input shaft until it fit the actual pilot bearing that I was actually using. I also test fit the disc on the input shaft. It had no problems.
Reassemble and then everything went smoothly.
BUT there sure was a lot of swearing until I had it finally figured out.
