Old engine leaks oil
How much oil was in the pan?
regards, tom0 -
It was full according to the dipstick, but not overflowing.0
which which engine are we talking about?0
262 six cylinder0
I don't know why I can't rotate this picture so that it doesn't come out sideways.0 -
This is the setup before I installed the dipstick....0
This help0
That looks 90 degrees better!0
Thank you Lostmind. It was always upright every time I attached it, but kept ending up sideways when I posted the comment. I still don't know why that happened.0
It sounds like you have an over pressurization of the pan, when was the motor last gone through (if ever)?
my only thought is that you have weak rings causing a pressure in the pan.(if it’s not rebuilt try marvel mystery oil in the cylinders to loosen up the rings and burn off the carbon holding the rings)
just a thought0 -
The dipstick is hard to see, looks like the wrong one?
Maybe pull the starter and look for crack or missing plug?0 -
I figured it out. Oil cap is from another engine and wasn't allowing pressure from the engine to escape. Once I cranked it without the oil feed cap, the oil didn't spew out from under the dipstick.0
BTW, Lostmind, the reason the dipstick is hard to see in the picture is because it had been removed.0
BTW, I dig the homemade engine testing stand.
