Throw out bearing positioning
I coupled my engine and transmission today, checked that the linkage was in the throwout bearing correctly before I finished bolting them together. After I got it into the car, I got worried about how to verify that the bearing is still in the right place? I know I grabbed the u joint and it turned the transmission which would have moved the pilot shaft and likely turned the bearing, but the linkage seems to move about the same amount.
How does one inspect that it is still right?
Sorry 1946 supersix 212 i60
The pawls on the clutch linkage inside of the bell housing will be resting on the flats on the TO bearing if installed correctly. Also if you push your clutch pedal in and you feel the strong clutch springs, you know it’s working0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
