Ethanol Proof Replacement For Solder ?
Our wonderful British 5% ethanol fuel has dissolved the solder on my fuel tank pick-up connections.
Is there an ethanol resistant epoxy putty/sealant/glue that I can use to replace the solder ?
I would use JB Weld but, apparently, it isn't ethanol proof.
It's an odd pick-up pipe as it passes through the top of the sender unit into the tank and It looks like it might be a lash-up job by the previous owner that I perpetuated when I had a new tank made.
But from memory, there was no separate hole for the pick-up pipe in the old tank either so perhaps it was originally supposed to go through the top of the sender ?
