Speaking only for myself, I never pull the knob out when backing up. I think there's some sort of internal pushrod that does whatever needs to be done, whenever you throw the car into reverse.
However, my OD is a 1940, which has a number of differences from the 1941 and up OD transmissions.
The OD has both electrical and mechanical protection to keep the car from going into reverse while OD is engaged. The internal mechanical linkage won’t allow you to shift into reverse and The governor won’t allow the OD to kick in until 22 mph. I’ve never had to pull the OD lever out to go in reverse. I have both a R9-B1 and an R10 OD
"The final thing to avoid that can immediately damage the overdrive is
to reverse or start in first gear while overdrive is engaged. This will
instantly crush the needle bearings inside the sun gear and require a
several hundred dollar repair.
Fortunately, this mistake is only
possible if you bypass electrical circuits by connecting the solenoid to
the overdrive toggle switch, removing the kick down switch, relay, and
governor from the circuit. This is not a factory installation, but some
car owners have done this over the years, and most end up later paying
the repair cost as a result."
53 Super Wasp Coupe ready for restoration 53 Studebaker Coupe Custom 64 Champ pickup Wellborn, Fl
Well the website statement you posted may be true for first gear with those electrical conditions stated but It’s still impossible mechanically to engage reverse on the Hudson versions (I can only speak to the R9 and R10), even if you bypassed the electrical. Not all versions of the BW OD’s are the same. Take a look at the Packard version vs the Hudson version. Both are R9’s but differently laid out. They don’t interchange.
Look. I’ve been driving my 46 R9-B1 for years and never once disengaged the OD with the cable.
You can leave the OD cable all the time. When you put the car in reverse the OD gets mechanically locked out. A caution though is when parking, if the car rolls forward in gear that will damage the OD unit. The car will hold if the car is uphill. Best practice is to disengage the OD when parking on an incline.
51 Hornet Club Coupe 51 Hornet Sedan 51 Commodore Six Club Coupe 50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire) 49 Super Six Sedan
There are other factors to take into account. My '53 Hornet will engage reverse alright with the knob pushed in, but the car will not do anything, because it has the wrong selector shaft ( from a non o.d transmission,) so the overdrive is not disengaged. When I let the clutch out all that happens is the free wheeling rollers turn. So I have to manually pull the knob out if I want to go backwards. Slightly inconvenient, but much easier than removing the transmission and overdrive and replacing the shaft.
Yiu can leave it push it all the time, even when parking, just set the brake so the car can’t roll forward. That will damage the OD unit. Otherwise when shifting to reverse mechanically the OD gets kicked out by design.
ok, just found this-
https://vintageautogarage.com/blog/troubleshooting-the-borg-warner-overdrive-in-a-classic-car/
"The final thing to avoid that can immediately damage the overdrive is to reverse or start in first gear while overdrive is engaged. This will instantly crush the needle bearings inside the sun gear and require a several hundred dollar repair.
Fortunately, this mistake is only possible if you bypass electrical circuits by connecting the solenoid to the overdrive toggle switch, removing the kick down switch, relay, and governor from the circuit. This is not a factory installation, but some car owners have done this over the years, and most end up later paying the repair cost as a result."
64 Champ pickup
Wellborn, Fl
51 Hornet Sedan
49 Super Six Sedan
51 Hornet Sedan
49 Super Six Sedan
51 Hornet Sedan
49 Super Six Sedan
